It is currently Mon Aug 18, 2025 7:35 am
Post new topic Reply to topic  [ 33 posts ]  Go to page Previous  1, 2
PostPosted: Thu May 08, 2014 3:26 am
I can't justify it, but I'm probably with Rod.
Proper booth, extraction, lighting, no compromises.
PostPosted: Thu May 08, 2014 3:45 am
Most of my instruments get a nitro finish, I have a dedicated and well equipped spray booth. It takes time and money to set it up and learn how to use it, but I agree that the prep work is even more important. And the better you get at it, the more concerned you will be with all the other little details, because the better the finish, the more they will show. Learning how to get a nice finish will help you become a better builder in these areas as well, because it requires great dicipline and lots of practice to refine it to truly professional level. I agree that the biggest cost here is time, not the equipment or materials.
Sent fra min SM-G900F via Tapatalk
PostPosted: Thu May 08, 2014 7:23 am
Last Name: Howard
City: Magnolia
State: Delaware
Zip/Postal Code: 19962
Goodin wrote:
Great topic. After making myself sick for 3 days, and thinking my liver had died on me, I will never again spray nitro without a proper spray booth and IDLH respiratory equipment. That stuff is nasty and should always be taken seriously. So, I will probably farm out a nitro finish until I get a proper booth set up (and drying box).
Would anyone care to give a realistic estimate for a professional nitro spray job? Just to spray it and let it cure for 3 weeks (the builder would do all prep work, taping off, final sanding, and buffing).
I do a Nitro finish on an average acoustic guitar for $415, that includes all prep work and final cut and buff. You simply sand out your work at 120 and get it to me I do the rest. Prep is such an important part of a good stable finish I will always prep my own work as I am the one who must stand behind that work. I feel he same about the final buff....It is what people see, and if I do the work I want them to see a finish on par with any fine instrument out there.
Brian
PostPosted: Thu May 08, 2014 8:21 am
"The finishers I have worked with expect the instrument to be properly prepped before shipment. Sanded to 220 and no missed scratches. A definite up charge if they have to do additional surface prep."
Hi Terence,
I'm sure you do excellent prep work, and finishers expect most of the sanding to be done by the builder, but most good finishers will "touch up" places that their trained eyes tell them will make a difference in the finish. It may be something as small as handling marks -oil from a persons hands, rub marks, etc. They don't charge for that, it's an expected part of finishing. If they have to do significant sanding then expect an added charge.
PostPosted: Fri May 09, 2014 7:37 am
Last Name: Howard
City: Magnolia
State: Delaware
I prefer to do my own sanding if I am finishing because, no offense, but most don't do it correctly. Most film failures down the line can be directly attributed to bad prep work, in particular sanding. Over sanding is a common problem when people prep to finish wood and even a bit more so among guitar makers. Also wood begins to oxidize as soon as you are done sanding it, sealer should always be applied within 36 hours of sanding for best adhesion.
Brian
PostPosted: Fri May 09, 2014 10:59 am
First name: Gil
Last Name: Draper
City: Knoxville
State: Tennessee
Brian, that seems like a reasonable price. Does that include pore filling?
PostPosted: Fri May 09, 2014 11:21 am
Brian, what are you using for pore filling these days?
Chuck
PostPosted: Sat May 10, 2014 8:01 am
Last Name: Howard
City: Magnolia
State: Delaware
Yep, includes pore filling. The basic finish like I mentioned uses a paste filler. Basically the same finish as Martin, Gibson etc. I also offer an epoxy fill for a slight upcharge, it is nice to preserve clarity especially if one has used sapwood as an accent.
Brian
These users thanked the author B. Howard for the post: Goodin (Sat May 10, 2014 6:46 pm)
Users browsing this forum: Michaeldc and 14 guests
